My stick is not found in ESA PRO. I can only start in demo mode.
In ESA2 beta it is found, but I can't read or write on card.
In tools.exe everything is fine. I can do everything.
Can anyone help me?
STICK-KE1
Firmware 1.19
OS: win7 x64
Thanks.
Jens
STICK-KE1 is not found in ESA PRO
Re: STICK-KE1 is not found in ESA PRO
download the latest ESA Pro and update the firmware with the included tools.exe
if it is still not working, try to format or replace the SD memory card
I use the latest software (26.4.13), the firmware already has been 1.19, but I updated it too.
I formatted the sd card with a notebook, now the Stick always blinks and doesn't accept it. Impossible to write. ;(
Bought a second card. Same here.
Greets.
Greets.
send over an e-mail if you're still having problems with this
I have the same problem with one of the stick
tomorrow at work
what you have explained try.if it does not work you can hear it from me
tomorrow at work
problem is solved happy
Formatting the SD and new firmware
thanks again for the correct interpretation
now I need to work on Friday the stick de3
