Dear Sirs,
the Movie recorder doesn't work for me.
I try to save an avi file and I get an empty video, all frames are white.
Any help?
Easy view 3D Sep 28
Re: Easy view 3D Sep 28
Hi, we are working on this problem, we will have a new version available this week
there are problems when you play strobe work. The rate of bursts does not change linearly. The only problem is the screen itself the unit runs properly. thank you
Does this happen when advanced rendering is disabled?
Check that the strobe property is set correctly in the fixture profile. You can set a minimum and maximum speed here and set linear or random.
How do i create a fixture in the scanlibrary. Editor ?
I need to make a 7 Channel Par 64 Led.
Can anyone explain,
Best wishes
Thomas
Can anyone explain,
Best wishes
Thomas
