Hi, Simon
- exporting show still crashes s2 on w7 randomly
- I think the dimmerchannel doesn't work naturally when overlaying scenes it gets 100% (at this time I'm not sure)
- easytime need loopoption for single-ficture-loop and loop-all
- mega bar page still doesn't display macro.
- midiconsole mixes pages->doubles commands. set command for page 1 it appears in page 2 too.
- what does add-sub mean, when i use this for a switch nothing happens? add and sub works
- is it possible to seperate scenes when using different layouts? for example masterpage gets 3 groups with independent sceneclusters.
would helpful, because many clubs mix fixtures, so it gets impossible to use pages for the dancefloor. switches doesn't support fadeout and must be deactivated.
-grouprect need an option to update fixtures or recalculation. it takes weeks to build every scene again, only because one fixture must be changed (par56 broke is replaced by par64)
cedric
15 sept beta
Re: 15 sept beta
Hi cedric,
you posted in the Suite 1 forum here, but I think you are talking about Suite 2.
There is also a new Suite 2 Beta release from 24. Sep.
Topic was "Some findings in Beta 24. Aug".
There´s a thread about this in the Suite 2 forum.
Gruß Gernot
Have you read my answer in the Suite 2 forum already ?- mega bar page still doesn't display macro.
Good question, I´ve always forgot to ask.- what does add-sub mean, when i use this for a switch nothing happens?
I´m not sure what you are referring to, but maybe it has something to do with page priority ?I think the dimmerchannel doesn't work naturally when overlaying scenes it gets 100%
Gruß Gernot
Re: 15 sept beta
ups, sometimes the s2forum is on first place in my browser sometimes below... was in a hurry and mixed it up... :)
should be referring to suite2.
I will try the new beta
cedric
I tried every switch priority but the dimmer feels like its added or set to 100%.I´m not sure what you are referring to, but maybe it has something to do with page priority ?
cedric
