I have a problem,
For my work I need to replace a drive.
on the memory card, no data is present.
Now I have to write a new program to control two LED DMX beams.
is intended that a variety of buttons are used for a certain color, it also must be able to be dimmed,
can someone explain to me how to do this?
greetings stefan from Netherlands
problem
Re: problem
Hi Stefan,
Yes you can do this using ESA2 or ESA Pro software, which both work with the Stick-KE1/KU1.
ESA Pro Manual :
https://www.nicolaudie.com/manuals/#/en/esa-pro/welcome
Video Tutorials: https://www.youtube.com/watch?v=GkiAXS4 ... y_QABtedTH
ESA 2 Manual :
https://www.nicolaudie.com/manuals/#/en ... e-we-start
Create a different scene for each color and then assign the scenes to the different buttons in the Standalone tab. Then write the show to your Stick1. The Stick1-KU1 and KE1 allow you to dim any scene using the dimmer slider at the bottom of the panel.
ESA Pro Manual :
ESA 2 Manual :
